'07 Ford Taurus Amp Install - Wiring Help
robert8998
Not experienced with this all, a friend is helping me out for the most part, but we need to know the speaker wire colors. I've looked up several diagrams and found a bunch of info on the colors, but they don't match up at all. I've been seeing the following everywhere:
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
When in reality, the unit in the left side of the trunk has these wires:
There's no black/violet or brown/yellow wire, etc. We have everything else going fine, but if anyone could tell me what both of the different sets of wires do or if I'm looking at the wrong thing that would be appreciated. Sorry if it's a really simple mistake.
Not experienced with this all, a friend is helping me out for the most part, but we need to know the speaker wire colors. I've looked up several diagrams and found a bunch of info on the colors, but they don't match up at all. I've been seeing the following everywhere: Left Front Speaker Positive Wire (+): Orange/Green
Those aren't the speaker wires. That's why they don't match
that is the factory tuner located in the trunk. the plug on the right is the signal plug and the one on the left is the speaker output. from right to left as the picture shows, on the 8 pin side of the output harness
right rear - right rear + right front - right front + left rear - left rear + left front - left front +.
that is the factory tuner located in the trunk. the plug on the right is the signal plug and the one on the left is the speaker output. from right to left as the picture shows, on the 8 pin side of the output harnessright rear - right rear + right front - right front + left rear - left rear + left front - left front +.
Or that[emoji4]
robert8998
robert8998
Arizona
noble brown
AJ (ACE)
    Jun 28, 2026
