ngsm13
BSEE
Alright, so you're taping off your door, attatching the pods, then fill up to them to have absolutely no gap right?
If so, before you attatch the pods to the door... use something like a cut-off wheel to make gashes along the edge of your pod. Then attatch to the door. These small gashes will allow something for the body filler to grip/bond to a little better... so it will be less fragile when you pull it off the door.
As for filling the pods themselves... get some decent filler. I can't stand the filler from autozone. It will make life easier, if you alread bought the filler oh well.
Use the spreader to get your shape correct, and the biggest thing with body filler is to work with it while it's in the green stage. This is when it's holding shape or setting up in general... but will come off is pieces like grated cheese. Use some 36grit paper to knock down high spots and spreader marks during this stage.
Wait for it to cure/harden, then go at it sanding. Use the paper and your hand to make the contours smooth... if you don't have a soft taco (sanding pad) to use... here's a way to fold your paper to benefit (http://www.woodworkingtips.com/etips/etip020621sn.html)...
Or if you have a DA, you're golden //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif...
Vinyl you won't have to be too smooth... 80 grit will be fine...
//content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
nG
nG
