I bought the car not knowing the stock headunit can't be remove so what ideas do I take if I wanted to wire amps for sub, mid, high? Also hook up a crossover and EQ? I looked at audiocontrol EQL but don't know exactly how to start this setup.
you are close with the EQL but you need to look at spending a bit more money. you're going to need to use something more like an Audiocontrol DQL-8, especially if you want to have EQ and X-over controls. I personally would go with Audiocontrol but there are other units on the market that are just as good.I bought the car not knowing the stock headunit can't be remove so what ideas do I take if I wanted to wire amps for sub, mid, high? Also hook up a crossover and EQ? I looked at audiocontrol EQL but don't know exactly how to start this setup.
a lot of the new vehicles do not have a dash kit made b/c car manufactures are starting to make the stock headunit cosmetically blend into the car. this is especially true on higher end brands like Acura, Lexus, etc... also a regular LOC will not work b/c of a stock amp that has built in crossover points.what do you mean it cannot be removed??or is it that you do not want to due to be still making monthly payments??all hus are removable..99.8%..and more than likely will need be to bypass the stock amp with a loc for after market amplifiers
http://sound-better.net/Support/Manuals/Autosound/DQL-8_Owners_Manual.pdfAo what do I do? Im stuck. Please help. DQL would be fine but please tell me how to wire and what I need
thank you so much for the info. this is a great help.
