04 Grand prix Rear Deck Speakers
rockyahfosgate
I have a 2004 Grand Prix with 6x9's in the rear deck what I am trying to do is install alpines all around and what people are telling me is that im going to have to remove the back seat to take the speakers out... Is this true? And if this IS true then could someone tell me in a lil bit detail what bolts and clips to take out and where, to shorten the process... Thanks
i think like every car is like that... takes me like an hour to get my seat out //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
on alot of cars, its 2 or 3 bolts at the bottom of the rear cushon, usually near where the seatbelt hooks in, then a latch that you pull up then out on.
Yup, your going to have to. I have a regal(pretty much the same car). And what you have to do is take out the bottom of the seat first, there should be a black ring on either side at the bottom of the seat to release it. If not give it a pull it will pop up. then you'll have to remove four nuts. The two big ones in the middle will have the seat belt latches on them, and then there will be a little one on either side. Then what you should do is pop the two panels off of the back pillars to make it a lot easier to remove the back deck cover(they will just pop off). then you pop out the clips holding the back deck cover on. All you have to do after that is swap the speakers and put everything back in;)
^^ that covers it exactly. I would deaden the metal around the speakers while you have it all torn out. I got a few rattles when I added subs so I had to take it all apart again to get rid of them. 2000 grand prix for reference.
38
902
697
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
858
rockyahfosgate
rockyahfosgate
ada, mi
john#21
    May 12, 2024
Brendon Jenness
    May 11, 2024
