03 focus budget build/rebuild
MarcusFranz
Cocoa, Fl
Well like many people my budget is almost none, I am young, 17 and i intend to get the best out of what i have. That said, enjoy, critique, and help.
The car...
03 Ford focus sedan
Same subs old box
Sub before these the type x on right
Subs before that
first sub in first box i built
first sub in prefab
Equipment going into/already in the car
Headunit- phase linear/jensen uv10
Wiring/Electrical- 4 gauge back to amp/amps 0 gauge for big 3 possible new battery
Amps- Orion cobalt 200.4 (will run subs until i get the second amp) Older alpine V12 four channel will run subs once i get it
Subs- 2x Rf p1 15s s4 vc
Box- about 6 cubes tuned to 29hz
Highs/Mids- No clue yet i do have some boston 2 inch computer speakers being used for highs tho
what kind of sofware did you use?? So if you want to go and buy some stuff you'll have to stack them up on your back seat heh //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well its not super loud, but i gets low and i dont have any trunk rattle because subs are fired forward and the trunk is sealed off, its about as loud as before but remember im still only on half the reccomended power and its not super clean power... i would imagine if i throw 500 clean watts at it it'll slam pretty good
hmm....a 4 channel powering subs? you need to save up and get a class d mono amp. and yes that is some THIN speaker wire. I see that causing problems before long. also what was the point of the screws showing on the prefab box? doesnt make much since.
this but nice setup for low budget
Wiring color code should be ISO, just like American radios. If you get your vehicle specific radio harness, it should have the same colors as that...
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
MarcusFranz
MarcusFranz
Cocoa, Fl
MarcusFranz
