01 Jeep Grand Cherokee: NEED HELP installing headunit
RADIO 12V red/white at the radio
RADIO GROUND black at the radio
RADIO SWITCH white/red at the radio
RADIO ILLUMINATE none
POWER ANTENNA none
"borrowed off of 12volt.com for 2001 jeep cherokee stereo wiring"
options are buy 12 3 ft pieces of wire and ttap the factory wires after unplugging the amp
bad idea
buy the bypass and match colors :p (i recommend)
retain factory amp (which u will be happier with headunit internal amp imo) and the harness to do this is prob very expensive
RADIO 12V red/white at the radio RADIO GROUND black at the radio
POWER ANTENNA none
So BUY the harness...//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
so the only other option would by cutting wires correct???
they make a harness to change headunit and keep ur factory amp, i think u will be more pleased with the internal amp(your stereo) then with the factory amp being retained.
and that harness to keep the factory amp is prob very expnesive as most of them are
fixed
So BUY the harness...//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gifso the only other option would by cutting wires correct???
no u dont have to cut the wires, do u know what ttaps are?????
you could unplug the harness look up the wiring diagram and tao into the wires no cutting that way u could put the factory radio back in.
either way you have to run the wires from your stereo to after that amp,
spend the 30 bucks and make your life easy
no amp will be BYPASSED hence the name of the item bypass harness
-------- A------------ B----------------C
()()()()-----------------l_l---------------l_l
A.speaker wires to speakers
b. factory amp
c. faxctory headunit
after new h/u and harness will look like this
()()()()---------- * l_l * ---------l_l
********* l --------------l
Less than a month from now: FiQ 18" + AQ2200Any second (UPS): Alpinex100
My Jeep came with the Infinity Gold speakers/amp etc...
So I need help wiring me new headunit...do I bypass my amp or buy the harness adapter which costs a lot...and dont wanna do.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
You are such as **** noob with all these jeep help threads. just install the **** head unit, its soo easy just match color to color and then whenever you get components and a front stage amp bypass the amp by taking out the two harness on the infinity amp under the rear seat( passenger side on an '04).
theres NO big need or reason to bypass the factory amp when you are gonna use stock door speakers anyways. It won't yeild much difference in sound going from the Head unit straight to the speakers instead of stopping at the factory amp first with stock door speakers,thats just a waste of time. just install the Head unit for now running to the factory amp and later get comps asap and an amp for them. then problem solved and you would hear a difference.
god dam its all common sense.
GrandCherokee
GrandCherokee
Orlando, FL
evildave101
michigan born
    May 14, 2026
michigan born
    May 14, 2026
