00 Silverado Ext. Cab Build
xtremekustomz
Just got started last week so I am still in the design process. I do have some pictures though.
deadener
deadener2
ensolite
ensolite2
door
dash
Looking good I have been wanting to deaden my 05 Silverado any advice/tips Im a newbie so dont have much experience??
I would highly recommend deadening it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif It is AMAZING the difference. I worked on it today and got the rest of the dash framed and wrapped with fleece. Will be glassing soon. Anyway it is pretty easy to do. Not a whole lot of work taking it apart. If you have any questions just send me a pm.
My friend has one of those. Are there any tips/tricks for getting the door panels off?
What year model is it? The 99-02 is the same I believe and I think the 03-06 is different. On the 99-02 basically you take off the top piece that covers where the power windows are, then pop the door lock piece off, take off the trim rind around the door handle, pop off the window/door locks panel, remove 7mm bolt behind that panel and 1 right underneath the handle that you grab to shut the door. There might be one at the bottom of the panel but I don't know for sure, mine didn't have one. After that just pull up on the panel and pull out. You will have to disconnect the door light and window/door lock switches.
For the 03 up it is basically the same except you can't pop off the window/door lock piece. It has a bolt that holds it on the door.
xtremekustomz
xtremekustomz
Northwest Florida
xtremekustomz
