0/1 ga wire in my 2000 Blazer
smullen
Has anyone here ran 0/1 gauge from front to rear on a 2nd Gen Blazer?
I have a 2000 Blazer and I want to run 0/1 from the front to the rear and connect my 3 Optima Yellow cells,
from them to the Power Distribution Blocks, then smaller gauge to each of devices.
I need to find a place to run it throught the firewall, but I don't se a lot of places to drill a 1" hole...
The reason I want 0/1 gauge and 3 extra batterys is that my audio system will put out about 3500-4000 watts and then the airbag setup has 2 compressers that draw 23 amps each.
Also, I go to alot of car shows and I want as much parking lot time as possible.
I don't want to run say 2gauge or smaller and then have to go through all this again and upgrade... That and I have the 0/1 Gauge already.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
This will be fused at the front and rear and I will also be adding a HI Output Alternator and maybe a Battery Isolater if needed.
I have posted this question to a few other boards and didn't really get much help.
I've either got, You don't need 0/1 gauge or its easy...
Any help would be great.
Scott
Here are a few pics of my Blazer.
http://www.teamxratedstl.com/membersrides/stlouismo/chevys10blazer/index.htm
there should be like a grommet (sp) in the firewall. It's just a black patch, and u should run it thru there.
if u need to drilll a hole just make sure when u drill u dont drill something dat u r not supposed to, ie: wires.
it can be a ***** to pass the wire thru or something, but once it goes from the engine bay to the inside it's easy after taht
smullen
smullen
St. Louis
Matador
