psi
  1. ekah
    Featured I need help deciding which fuse for dist block
    Going to buy a amp kit from knuknkcept but they're asking which fuse do I want to use Which are 150 200 250 300. I'm not sure which fuse rating I'm suppose to use. Would be in a 2003 4runner Stock alternator Skar 3500skv Precision Power 900.4 With deaf bonce speakers and tweeters 2 psi...
  2. ekah
    should i get another sub or amp
    i was thinking of getting another psi plat 2  or was thinking of getting the wolfram 2400 im running one plat2 on a cab1600  which would i get a better result from a single plat2 on a wolfram2400 or 2 plat2's on a single cab1600  or would it be the same where i would clip in the same...
  3. S
    port direction and fun stuff
    18" sub with HCCA motor with PSI platform 3 basket and soft parts, 8.75cu ft box at 32Hz. In the back of a 98 k1500. Had the port towards the rear wall. Only had about 4" of space between the port and wall so I did port forward today because it was being choked. I have way more windshield flex...
  4. germandark
    (2) PSI Platform 2 [HD Cone, Stiff Spiders, Direct 8ga to sewn leads]
    Item(s) for Sale: (2) Platform 2 12" - CUSTOM BUILT SUBWOOFER Item(s) Description/Condition: 82mm XL FW - D2 (1.5) 2 – 8" stiff progressive roll spiders Sewn leadwire 8ga direct connect (RED/BLACK) 12" HD cone assembly 6" poly dome dustcap w/ LARGE RED PSI logo Price: $550+shipping...
  5. S
    bass head problems...
    Aight well let's start with this. I have a 98 k1500 with a HCCA PSI 18. Its all of a platform 3 with a HCCA motor. Its in a 8.75 cu ft box tuned at 32Hz. I had stock alt and stock battery. I have Polk 6.5s in the doors. And 0 gauge to the amp and 0 gauge ground. Been having tons of problems with...
  6. S
    2 brand new fully loaded 15 platform 2. BEAST SUBS!!!
    Item(s) for Sale: 2 15 platform 2 fully loaded Item(s) Description/Condition: Brand new still in wrapping one was taken out just to show what it looks like Price: 600 or trade for 2 12s and an amp or anything u have to offer the worst I can say is no Shipping and Miscellaneous Item...
  7. S
    Amp Suggestion
    So in my Dodge Magnum I have two PSI Platform 2 12"s (1000W RMS each) in fiberglassed pocket enclosures with approx .68-.71 cu ft. airspace. I know that little airspace *****, but I need the trunk space, and Dave at PSI built them with my small airspace in mind. I'm currently running an old...
  8. TheJesus
    FS: 4x PSI/Ti/DC Level 6 D.7 15" (4" monsters)
    1. Product: 4x 15" PSI/Ti/DC Level 6 D.7 2. Specs: DC Level 6 M2 Motor (4" coil, 85lbs) 15" Ti Basket PSI Recone (five 10" spiders w/ two spacers, 8GA direct leads, triple sewn leads, CF cap, D.7 107MM coil, red PSI logo) Rated by David for 5000 RMS daily (I don't think he rates anything...
  9. 93Exploder
    PSI PF 2 18" or Fi BL 18"?
    Which should I go with and why? I want lows, but still do want some decent SQ.
  10. A
    2 Like New Psi 12's Fully Upgraded
    Item(s) for Sale: 2 Fully upgraded Psi 12's Dual 1's (Platform 1 but basically platform 2) With the upgrades these handle and sound like platform 2's 6 months old and still under warranty Item(s) Description/Condition: Power Handling Ratings: Hi Performance RMS Power Handling - 1000 watts...
  11. mattj
    Sold FS: RD Audio 1800.1 *2300rms@1ohm* PROTOTYPE 1 of 2
    1. Product: RD Audio 1800.1 amp PROTOTYPE 1 of 2 made 2. Specs: 2300rms at 1 ohm. 1200rms at 2 ohm. It doesnt have markings for inputs but I will provide the owner with the layout. I was told that it was only 1 ohm stable but I havent seen it really get all that warm after playing full tilt...
  12. TeamPSI
    Radom subwoofer pics from FixMySpeaker.com/ PSI Car audio....
    Haven't been here in a bit, and figured I'd drop a few random shots of some of the latest subs we've been building/re-building here at the shop. Full pictorials with step-by-step build pics are at our forum, if you want to see them all. I'll just post finished pics in this post. Don't mean to...
