JoshuaKNelson
I try to set the gain on my amplifier using a multimeter and a 40Hz tone only to have the voltage bounce all over the place. This has happened with 2 amplifiers in a row that were brand new and never hooked up to the subwoofers. I hooked up the power and ground wires, the remote wire and the rca cables. Then hooked up a multimeter to the speaker output on DC volts setting. Played a 40Hz tone off my usb at almost full volume with my bass knob all the way up. I'm using a 3000 watt amplifier that will be running at .5 ohms. So the target voltage when you take the square root of watts times ohms is about 37 volts. I start to slowly increase the gain and all it does is bounce from .2 to
.4 then back down to .1 then back up, etc. Not stable like it should be. The ac voltage on my rca cables going into the amp is stable at 2.5 volts. Not bouncing. My alternators voltage is 14.3. My batteries both hold a charge. All my grounds read 0 resistance to .1 on the ohms setting. Everything is normal. If I continue to increase the gain it will bounce from positive numbers and down into negative numbers then the amp will go into protect. I have no idea what is causing this problem. My setup has worked flawlessly for 2 years and now I can't set the gain or come anywhere near the voltage I need to set it too on any amplifier. This isn't my first install. Ive been doing it for over 20 years and have never encountered this issue. What could possibly be wrong? THANKS.
