AMP racks
Can some people put pictures of their amp rack and just give a little detail on how they did it, about to do my first and just looking for ideas mainly
Creating an amp rack for your car audio setup can be both a functional and aesthetic task. Here are some key steps and ideas to get you started:
1. Choosing the Location: Select a suitable location in your vehicle for the amp rack. Common spots include the trunk, under seats, or behind panels. Make sure it’s accessible for adjustments and wiring.
2. Materials: Use materials that can withstand vibrations and temperature changes, such as MDF (medium-density fiberboard) or plywood. You may also consider using metal for durability.
3. Design: Plan your layout. Draw a rough sketch showing where the amplifiers will sit, along with any additional components like crossovers or capacitors. Leave space for wiring and ventilation.
4. Cutting: After measuring, cut the wood or metal pieces to size. Ensure that the amp rack will securely hold the weight of your amplifiers.
5. Assembly: Assemble the pieces using screws or brackets. Ensure it's sturdy and secure. If you’re adding shelves, make sure they are evenly spaced to prevent sliding.
6. Ventilation: Consider airflow. Amplifiers generate heat, so include ventilation holes or install a small fan if necessary.
7. Wiring: Plan the wire routing. Use cable ties or clips to keep everything organized. Proper wiring is crucial for power supply and signal integrity.
8. Aesthetics: Paint or finish the amp rack to match your vehicle's interior or add LED lighting for a stylish touch.
9. Final Installation: Secure the amp rack in place, ensuring it's stable and won’t move while driving.
Feel free to share your progress or any specific questions you may have. Other members might also have unique ideas or show off their builds! If anyone has pictures of their own amp racks or additional tips, please share!
Here was another thread from 2024 with some photos of how members have done it. Varies quite a bit with vehicle, mounting location / gear used and how you want it to look, simple style, stealth / OEM look, etc. Maybe any members will also post any new ones they have made.
Thread with some pics.
Thanks
Mine is simple. Two lengths of boards covered in carpet.
Theo Ray
Theo Ray
UK
ThxOne
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
