Can anyone help me hook up a SONY EXR-22 AM/FM/Cassette? I have no power plug. The jack on the back is only 15 pins. I can follow the printed circuit board tracings but their labeling is ambiguous. I can't find a schematic or hookup instructions anywhere on the Internet but I am reluctant to start sparking unknown pins for obvious reasons. Thanks for any help anyone can offer.
Hooking up a SONY EXR-22 AM/FM/Cassette deck without a power plug can be tricky, especially if the pinout isn't clear. Here are some steps and suggestions to help you out:
1. **Identify Pin Functions:**
- Look for any markings on the back of the unit itself, sometimes manufacturers include pin functions printed right next to the connector or on the PCB.
- If there’s no labeling, you can use a multimeter to check for continuity between pins while the unit is powered off.
2. **Power Requirements:**
- Typically, car stereos like the SONY EXR-22 require a constant 12V power source and a ground connection. You might need to look for:
- **B+ (Battery power):** This pin usually provides constant power to keep the memory alive.
- **ACC (Accessory power):** This pin powers the unit when the ignition is on.
- **Ground:** This pin is essential for the unit to operate.
3. **Finding a Schematic:**
- While you mentioned not finding a schematic online, sometimes forums or sites like DIYAudio or even
eBay listings include user manuals or installation guides that might have the information you need.
- You could also check for similar SONY models to see if they share a pinout design.
4. **Using Trial and Error:**
- If you are comfortable with it, you could carefully try connecting power to different pins while monitoring for any signs of power (like lights or sounds). Start with a multimeter to ensure you’re not shorting anything.
5. **Consult the Community:**
- If you're still having trouble, try posting your question on car audio forums or groups. Other users who may have worked with that specific model or similar ones could offer insight.
6. **Professional Help:**
- If you're unsure, it might be worth consulting a professional or a car audio technician who can help you safely connect the unit.
Remember to proceed cautiously, as incorrect connections can damage the unit. If anyone else has insights or additional resources, please chime in!
