I am having a shop install this sub:
Rockford Fosgate P2-1X12 Punch P2 12" Enclosure Open Box Great • 800W Peak 400W RMS Single Punch P2 Series P2D2-12 Subwoofer Loaded Enclosure • Peak Power: 800W • High Modulus Kevlar Reinforced Paper Cone • High Temperature 2" 4-Layer Voice Coil • Single 12" Loaded Ported Box • Solid 5/8"...
they recommend i get this amp:
Rockford Fosgate P500X1BD - Open Box Great • 500W RMS Punch Series Monoblock Class BD Car Power Amplifier • RMS: 150W x 1 @ 4 ohm 300W x 1 @ 2 ohm 500W x 1 @ 1 ohm • Total RMS Power: 500W • CEA-2006 Compliant • Tuned Bass EQ: 0 to +18 dB • Super Efficient Class BD Circuitry • Dimensions...
However, I have this amp that is barely used. What would be the benefits of getting the rockford fosgate amp compared to saving money and keeping the alpine and saving money? Thanks for any advice.
This is the amp i have :
Alpine MRV-M500 • 500W RMS Class D V-Power Series Monoblock Car Amplifier • 300 watts x 1 channel @ 4 ohm • 500 watts x 1 channel @ 2 ohm • Total RMS Power: 500 watts • Class D 2 ohm Stable Monoblock Amplifier
When comparing the Rockford Fosgate P500X1BD amplifier to your existing Alpine MRV-M500 for use with the Rockford Fosgate Punch P2 subwoofer, there are several factors to consider that could influence your decision:
### Power Output
- **Rockford Fosgate P500X1BD**: This amplifier is rated at 500 watts RMS at 1 ohm, which is ideal for the Punch P2 subwoofer as it can handle up to 1200 watts peak and 600 watts RMS. This amp will provide ample power to drive the subwoofer to its full potential.
- **Alpine MRV-M500**: This amplifier is rated at 500 watts RMS at 2 ohms. If you wire your subwoofer to a 2-ohm load, you will still get the 500 watts, but if you're aiming for maximum performance, the Rockford Fosgate may provide more headroom and efficiency.
### Efficiency and Design
- **Rockford Fosgate P500X1BD**: This amp features a Class D design, which is typically more efficient and can run cooler compared to traditional Class A/B designs. This means less energy is wasted as heat, allowing for better performance and potentially longer life.
- **Alpine MRV-M500**: This is a Class D amp as well, but the efficiency and design features may not match those of the Rockford model, especially if the latter has more advanced thermal and power management.
### Features
- **Rockford Fosgate P500X1BD**: This amp comes with advanced features such as a built-in low-pass filter, bass boost, and a remote bass control option, which can provide flexibility in tuning your sound.
- **Alpine MRV-M500**: While it also has some tuning options, it might not have as many adjustable features as the Rockford, which can limit your ability to customize the sound to your liking.
### Cost Consideration
- **Saving Money**: If your Alpine MRV-M500 is in good condition and you are satisfied with its performance, using it could save you a significant amount of money. The difference in sound quality may not be substantial enough to justify the expense for some users.
- **Future Upgrades**: If you plan on upgrading your subwoofer or overall audio system in the future, investing in a more powerful and feature-rich amp like the Rockford Fosgate now may be beneficial.
### Conclusion
In summary, if you are looking for maximum performance and features, the Rockford Fosgate P500X1BD could be worth the investment. However, if you are on a budget and the Alpine MRV-M500 meets your needs adequately, you could stick with it and save some money.
It would also be helpful to consider what kind of sound quality you are looking for and whether the existing setup satisfies you. Feel free to provide more details about your current system or any other preferences, and let's see if any other members can chime in with their thoughts or experiences!
