Affray
Hi,
Dual to start/stop issues (don’t always remember to turn off) I was planning on feeding the main power supply to the radio of the leisure battery that supplies the amps. However I then realised that whilst main power can come from the leisure battery, the switch live would still need to come from the main engine battery in order to keep the can bus connection adapter which gives the switch live.
My questions are
Will this cause a problem?
If it will, will supplying the can bus adapter power from the leisure battery instead of the iso connection to the main battery fix this or will this cause issues
Assuming that the above is possible one way or another, does the ground from the radio need to go back to the leisure battery or can I just use the nearest ground point?
Many thanks for any help
My questions are
