CarAudio.com Exclusive
Want to piece out a component set, getting the woofers and tweeters separately and avoid using the external X over box component sets use.
The tweeters I want to use are efficient aluminum domes so I was going to put them on headunit power to avoid running 2 sets kf wires to each side and put the woofers on on amp.
Issue I'm having is there doesn't seem to be any affordable inline lowpass crossovers and the lowpass on my amp only goes to 500hz. Was tryna find one to eliminate 3.5khz and up but can only find expensive ones that block only around 500hz and up
