Featured Bass knob cable
CarAudio.com Exclusive
Hello so I ran into a problem. I have the sundown SIA 3500 watt amp and the bass knob stopped working. I did some testing and found out it was the cable that connects the bass knob to the amp and not the entire bass knob. I did some research and found that the cable is a RJ12 6 pin but the problem is standard has white has pin 2 while the sundown cable has white has pin 5. Would a standard rj12 cable work. Here's a reference picture. Thank you for your help in advance.
The bass knob was already replaced. Then then the problem. What is the rating for the bass knob? Find one knob with in specs. Frequency, range, decibels/octave. Then match the settings to what your system requires.
Charlotte
5t4y_50L0
