Help me decide for best output (B2 Audio - Rage 8 or Skars SDR 12)
5t4y_50L0
I want my B2 audio but if I get better performance in my car with a 12 I'll go that route.
I have 2 B2 audio 8 and 2 skar 12, I'm going with one sub either way for best output at 33 Hz tune.
My goal is trunk space, as of now I have 2 B2 audio 8s in a 1.4 tuned to 40 Hz, not liking it struggle on low end. Current 29W 11.5H 19D.
Again the goal is 33 Hz with a single sub and depth 14 and width 30 height no more then 17
Can you please clarify your question or provide more details about your setup?
2019 Camaro, Factory HU, 2300 watt amp but going to run 500 RMS at 4 ohm with my amps availability of 650 at 4 ohms to whichever subwoofer I pick.
My question was which single sub should I go with for best sound, but later realized I'd need more cu.ft. with the 12 in skar to achieve 33 Hz
If I was to build a box with max specs the only way I can slide it into the trunk is through the backseat. 14x19 inches and width would be 30 in, but the actual distance from backseat to truck "depth" would have to stay inside of 14 or 15 in.
I did some rough calculations and came up with inverting Two B2 Audio 8 in RAGE subs in down fire, center port. I'm aware this Apps calculation isn't completely accurate and would need winisd and bass pro to further the process. I have both programs but am miles away from my laptop and never understood how to properly use the programs anyway, LoL. I always paid someone to design all my other enclosures but built them myself.
My current box
Dual B2 Audio RAGE 8s 500 RMS each
1.4 airspace 40 Hz
29W x 11.5H x 19D
Port 3x10 26.5 in L shape
Not happy with the 40 Hz tune, my music rolls off to soon, even with the HP defeated.
I'll include an image of my vision for a new setup
5t4y_50L0
5t4y_50L0
Oklahoma
5t4y_50L0
