Featured Alpine Type S Enclosure Build
It's going under the seats of my truck, max height is 7.25", depth is ~15".
In that case, I'd probably side fire the port. The downside is that frequencies emanating from sub may get muffled compared to the frequencies emanating from the port. Do you have an equalizer to fix that if it becomes an issue?
No, I don't have an equalizer.
I started looking at building this, but I would prefer to have my slot port, not a fan of the PVC tube.
Quick and dirty with a little resizing using Torres note the overall size has changed and using a 3" round port 13" long should put it about 1ft3 net tuned 35hz or so.
1/2" materials correct?
Does it completely change things if I use two 1.5" pipes? Seems like the 3" pipes are rare in my area.
Yes, that changes things because those do not have equivalent area. Area of a circle is pi*r^2. For a 3" pipe that's 7.07 in^2 and for two 1.5" pipes that's 3.53 in^2 total. You'd have to use 4 of the 1.5" pipes to achieve the same port area as a single 3".
Build it almost like you were about to but 27"w and side port the enclosure off center and I think you should be able to mount the sub to alleviate your original placement concerns.
Hey @shredder1, I'm finally getting around to building the box and realized the depth is off by 1.5." Can you confirm that if I do 6.5 (H), 30.5 (W), & 13.5 (D), that I'm not impacting the build in a negative manner given the previous specs? Additionally, what length does the port need to be now? Thank you.
6.5h x 30.5w x 13.5d using .5" materials?
Single baffled and using a round port?
What tuning are you after, do you have specific goals in mind?
Thx for quick response! Yes, .5" MDF, 35hz, single baffle and 3" PVC port. Height and Depth are locked at 6.5" & 13.5."
Its being built for an Alpine Type S 10D4
I'd go with 29.5"w and a 3" pvc 13.5" long
Qbenjamin
Qbenjamin
Braavos
Qbenjamin
