Powered sub before or after amp
I want to add a powered sub to my system. Should I connect it to the input or output of the amp?
To the output. Most powered subs have a high level input that is designed for that scenario.
There could be a downside. Some OEM amps have pre-set eq curves that protect the cheap OEM sub. Those curves will affect a downstream amp's performance. In that case you may need to use a signal leveler or epicenter to undo those pre-set curves.
RanK
RanK
WI
