C15 4 Ohm kicker
Enclosure is like 75% of the install imo, design it to beat or sub your choice. Maybe somewhere in between, either way it's the foundation of your music. With a good source and detailed hi's the next step is always lowz, nasty lowz if truth be told. Enclosure is more than a box... lol
This is what I have, I'm looking for a amp idk what to be looking for maybe a link to something that would be good.
Appreciate it ill go with it
I'd stick to lower power levels, especially utilizing a sealed enclosure. 4ga and 1000w or less is ez depending on the vehicle. If you have any experience just run ofc wire and be sure of your connections. Solid crimps and properly sized wire goes a long way. Set your levels carefully and don't clip... sealed enclosures
The Stinger Audio MT-1000.1 is easy on the wallet and the mt series are solid amps. It'll do about 400w @ 4 ohm which is about right for that sub.
This good wire for your power and ground runs. Pure copper and again easy on the wallet 😂
For wiring the sub itself...any true copper wire in 10g or 12g will work just fine.
As Shredder said though...the box will make or break how good a sub sounds.
Be careful when setting the amp up, whichever you go with. These subs are pretty low power like the old Comp model back in the day. The 15 is rated at 250 RMS and my experience with the 12” version (only rated at 150w RMS), it is not a sub you want to pump a ton of power into.
Those subs are pretty low power like the old Comp model back in the day. The 15 is rated at 250 RMS and my experience with the 12” version (only rated at 150w RMS), it is not a sub you want to pump a ton of power into.
Imo a 750w amp should be plenty... Btw... I've had awesome results with 500w myself.
In the right enclosure you get what you paid for, I'm NOT a fan of sealed on lower power subs.
Too susceptible to thermal/clipping and when it happens its usually too late.
Opya69
Opya69
Hobbs,nm
shredder1
