Malcolm.ross
Wanna use trailer thhn wire with my new car speakers but i don't know wich of the wires to use? Does it matter I can't find a consistent answer.
What is thhn wire? Got a Link for the wire you want to use?Wanna use trailer thhn wire with my new car speakers but i don't know wich of the wires to use? Does it matter I can't find a consistent answer.
No found it in my garage i know its a flat 4 trailer wire but thats about it and thank youWhat is thhn wire? Got a Link for the wire you want to use?
Welcome to the site by the way!!
Its copper wire. it will work if thats all you have and do not want to spend any money on new wire. Its safe to use for car speakers. I know most Trailer wiring is like 14ga copper. It can be used. Just make sure you connect + to + and Neg. to Neg. on the speakers and at the radio. That wiring is pretty rugged and weather resistant for quite a while too. It should be just fine. If you rather buy some new speaker wiring? Search for 16ga or 14ga in size on Ebay or other sitesNo found it in my garage i know its a flat 4 trailer wire but thats about it and thank you
Oh so I can run any of the thhn with the negative cable of the head unit and negative speaker and it works good?It should work just fine if the outer protective coating isnt corroding becoming brittle or copper wiring exposed.
You can split off two wires and use those from the Radio to the speaker be sure to mark or remember which wire you used for _ and + from the HU/Radio to attach to the speaker.Oh so I can run any of the thhn with the negative cable of the head unit and negative speaker and it works good?
Ok thank you very much finally have more then 2 tiny speakers in the 91 corolla wagonYou can split off two wires and use those from the Radio to the speaker be sure to mark or remember which wire you used for _ and + from the HU/Radio to attach to the speaker.
Thats a good running car!! hard to beat a Toyota Corolla for reliability and gas mileage.. Dammned good carsOk thank you very much finally have more then 2 tiny speakers in the 91 corolla wagon
Yea I love it thanks for the help have a good night manThats a good running car!! hard to beat a Toyota Corolla for reliability and gas mileage.. Dammned good cars
You got it man. Take careYea I love it thanks for the help have a good night man
