Random Picture Thread
"Scientists at CERN are trying to find out what the smallest building blocks of matter are. Normal matter is made of molecules..."
"Thousands of "lattice magnets" on the LHC bend and tighten the particles' trajectory. They are responsible for keeping the beams stable..."
'God Particle': New CERN Experiments Shed More Light on Higgs Boson Science News 'God Particle': New CERN Experiments Shed More Light on Higgs Boson After three years of scrutinizing the...”
“The collider was recently given a $150 million upgrade that allows atoms to be smashed together with even greater force, allowing it to recreate conditions similar to those during the earliest moments of the universe…”
View attachment 53613View attachment 53614View attachment 53615View attachment 53616
"The ATLAS experiment has released results confirming that the Higgs boson has spin 0 (it is a so-called “scalar”) and positive parity as predicted by the Standard Model, making it the only elementary scalar particle to be observed in nature."
"Spin is the intrinsic angular momentum of an elementary particle, measured in units of the reduced Planck’s constant ħ. In quantum field theory, the spin of a particle is related to its behaviour, for example particles with integer spin (0, 1, 2…), called bosons, can occupy the same quantum state at the same time. In contrast, particles with half-integer spin (1/2, 3/2, 5/2…) cannot. The known elementary constituents of matter (electron, quarks, neutrinos…) are spin 1/2 particles, whereas the particles (photon, W/Z, gluon) which mediate the known interactions (respectively electromagnetic, weak, strong) are spin 1 particles."
"CERN engineers control the frequency of the change to ensure the particles accelerate not in a continuous stream, but in closely spaced "bunches". ... allowing radio waves to interact with passing particle bunches. Each time a beam passes the electric field in an RF cavity, some of the energy from the radio waves is transferred to the ..."
"In the Large Hadron Collider (LHC) (https://home.cern/science/accelerators/large-hadron-collider), 16 RF cavities are housed in four cylindrical refrigerators called cryomodules, which enable them to work in a superconducting state.
Each cavity is driven by a high-power klystron, which is a tube containing electron beams. The electron beams are intensity-modulated to a frequency of 400 MHz, or 400 million oscillations per second..."
View attachment 53641View attachment 53642View attachment 53643View attachment 53644View attachment 53646View attachment 53647View attachment 53648View attachment 53649
"Spin is the intrinsic angular momentum of an elementary particle, measured in units of the reduced Planck’s constant ħ..."
"In Unicode, the special character ℏ (U+210F), represents the reduced Planck constant of quantum mechanics. In this context, it is pronounced "h-bar". The lowercase resembles the Cyrillic letter Tshe (ћ), or the astronomical symbol of Saturn (♄)."
“If you have been keeping up with the happenings of the CERN, the world’s most advanced scientific research facility, you might have noticed the statue of Shiva the Destroyer.
Shiva, the cosmic dancer, symbolizes the natural flow of divine energy. He takes part in Rudra Tandava – a dance representing destruction and rebirth- to reshape time and space with his wild thunderstorms…”
“Saturn as the grim reaper: Saturn, associated with time and the grim reaper, was usually depicted with a scythe. According to the prevailing cosmology of Aristotle, Western astronomers knew that, like all other heavenly bodies, the planet Saturn was perfect and spherical. The telescope therefore gave them a surprise….The problem was now solved, although Saturn's ring system still held surprises, as can be seen from the results of the recent flybys of the planet……..”
@Eggs
Slo_Ride
Regulator
Slo_Ride
ATLANTA
ThxOne
NorthFramingham
    Jun 30, 2026
