Help with a diagnoses.
You said that you are monitoring the voltage from the cigarette lighter socket. Have you checked the voltage at the amplifier terminal while you are playing it loud?
That’s is something I need to do. I did try and my meter refused to cooperate. I have an Amprobe. It’s a decent unit but it didn’t cooperate. I took it back to work. I need to invest in one for the house.
Here is a picture of the back setup. The XS D7500 Battery along with distribution and such are mounted under the wood I cut out. I put that carpet over the wood and mounted the amps on it.
curious how the gains were set?
Around 40%. I did not use any tool of measurement to set the gains. The 2015 pilot didn’t give me option much for a aftermarket stereo so I kept the factory stereo and installed the JL fix 86 processor. I did let an audio shop handle the tuning of that.
Hey thanks for the kind words. The subwoofers are Sundown X12’s V3 D2, wired to a 2ohm load to the Sundown 13,500/1 Monoblock amplifier. The gain is set around 40%. The enclosure is stage 3 dual ported mdf. I went for an in between kind of thing. What I mean is all types of music still sounds pretty good, but if I want to crank up the bass some to get that old school loud bass going I can. The small amplifier is a 4 channel alpine PDX 4.150. It supplies 2 sets of JL Audio 6.5 C3’s.
As for right now I’m finished. If I do anything else it will be something added to my front stage. I wouldn’t mind brightening that up some but I’m not sure how yet or what route I’d like to go. I’m not disappointed with the C3 performance but I think I want a little more umpf up front. The goal is to be able to play pretty loud without distortion. The ultimate goal would be to accomplish serious SQ while also being at a high listening level.
youbsilent357
youbsilent357
Usa
youbsilent357
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
