What the RCA is this??!
The RCAs wires have to be in the Red and White RCA inputs, otherwise you will only get Left channels to play sound. Put the Right RCA into the Front Right (RED) and the Left RCA into the Front Left (WHITE). Then rewire speakers accordingly.
SR-OUT AND SL-A-OUT i have them wired accordingly. Im trying to hook my subs up now to a different amp. But do i need to buy another rca cable for the subwoofer cable behind head unit?
My bad, I meant the RCAs at the amp
Can i put front on channel 2 and rear on channel 4?
SOrry i meant channel 2 and channel 3
So im thinking the amp i am using is bad on channel 1.. is there any test i can do to see if something is wrong with channel 1? I'm going to go look also at diyaudii. Heard they can help. im putting a performance teknique icbsm 775.. I'm going to run new wire again. Front left and front right will be wired in parallel. Same for the rears. I'm just looking to see if i can find a strap for this amp so it doesn't fall off the back seat.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
539
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
516
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
488
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
692
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
778
mikeizo
mikeizo
california
