Carlos1son
If I buy a w7 will a jd1000 push it? Or am I better with a W6? Also will the W7 be louder than the W6 on that amp?
The JD will definitely push that W7. It will put out ~750 watts. I have the 12w7 with an HD750/1 and it is a perfect combination.If I buy a w7 will a jd1000 push it? Or am I better with a W6? Also will the W7 be louder than the W6 on that amp?
I would guess yes. I have a burned out 10w3v3 that I took apart to practice rebuild and that voice coil is thick. The replacement I got is whimpy in comparison, so I assume one sounds good but two would sound awesome. You also get more cone area, so there is that.Is 2 W3 10s in a box louder than 1 w612?
I have 1 W0 wired to my jd1000 right now. If I get 2 w3’s in a box do I have to change anything on the amp or can I just plug the W3 box in with no changes?The w7 would likely be the loudest. A pair of 10w3s will definitely get loud. The w6 is more SQ oriented.
I connected the 2 subs at it hits harder than I thought w3s are a big difference than a w0I have 1 W0 wired to my jd1000 right now. If I get 2 w3’s in a box do I have to change anything on the amp or can I just plug the W3 box in with no changes?
I’m using a jd1000 pushing 2 w3 10s in a box.gotta reset the amp gain. heres how. the correct test tones are at the very bottom...
Amplifier Level Setting Guide
Note:The following article describes the Amplifier Level Setting process for most car audio amplifiers, regardless of brand. Specific target voltages for applicable JL Audio amplifiers are included...jlaudio.zendesk.com
what all audio gear you using? what vehicle?
