Winners only.
So the 11 in the house is not a real number unless they are all together. Got it.
If you choose to take it that way then go ahead.
And 2.3 is a fake number even though multiplying it by the 10 houses yields the exact 23 kids that live on the block.
Show me the .3 child.
I am amazed you made it to this age without stepping off the curb in front of a bus.
You literally are Mr Magoo, just blindly wandering through life from one moment to the next, completely unknowing.
Probably why you got injured on the job and accepted a payoff for you own stupidity.
Not proof because you are too lazy to go read it. Maybe you should have read it the first time instead of being an arrogant cock sucker.
Then go ahead and show us your “proof” that there are no nerves in bones.
Failure to show it means you can’t, which also means you are incorrect.
Go to or it.
You're both being retarded.
"You look like a fool Rob. Every time you post you show how stupid you are. Done!! Just move on. For the last god damn time. THROUGH NOT IN!!!
"Blood is supplied to mature compact bone through the Haversian canal. Haversian canals are formed when individual lamellae form concentric rings around larger longitudinal canals (approx. 50 µm in diameter) within the bone tissue. Haversian canals typically run parallel to the surface and along the long axis of the bone. The canals and the surrounding lamellae (8–15) are called a Haversian system or an osteon. A Haversian canal generally contains one or two capillaries and nerve fibers. The Haversian canals also surround nerve cells throughout the bone and communicate with osteocytes in lacunae (spaces within the dense bone matrix that contain the living bone cells) through canaliculi. This unique arrangement is conducive to the storage of mineral salt deposits that give bone tissue its strength".
You will argue out of ignorance. I encourage you to shut the **** up. You're stupid."
There is nothing here to say that nerves are not IN bones. If anything, this confirms that nerves are IN bone.
Per your post: “The Haversian canals also surround nerve cells throughout the bone and communicate with osteocytes in lacunae (spaces within the dense bone matrix that contain the living bone cells) through canaliculi.”
They are THROUGHOUT the bone. The definition of “throughout” is “in every part of (a place or object).”
Notice a very important word there: “IN”.
Your “proof” that there are no nerves in bones actually proves there are nerves in bones. Right there, in black and white.
You fail like a boss.
I said it before, you don't understand what you are reading but you will argue anyway. That is your goal. To argue. Argue the diick out of your mouth.
Nice try. You posted the proof that nerves are IN bones.
THROUGHOUT as a matter of fact, based on what you just posted.
THROUGHOUT means IN.
You literally disproved your own thesis. Hahahahahaha.
Maybe put your obsession with male genitals on hold when you try to argue. It might help reduce all of the failures you keep making.
Did you actually read? Or did you just pick out words you thought would support your stupidity.
I will break it down for you, the laymen. It states that tubes are generated inside the hollow parts of bones and in these "tubes" run the nerves. These tubes run throughout the bone and allow the nerves to pass through them.
Jackass.
YOU posted this as your proof. Are you now going to say it’s wrong?
There is no context list or altered. There is no change to the words. It is a direct quote from your post.
THROUGHOUT is the word YOU posted. Are you suggesting they goofed when they wrote the text, or that they don’t understand anatomy as well as you do, with your biology degree?
Whats your play?
Whats your play?
Here you go ignoring shit again.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
