Volume and port area recommendations?
Jonnyswboy
CarAudio.com Exclusive
448
92
Designing a box for 2x Fi SSD 18s and am not sure what volume/port area to use. Tuning to about 38hz and plan on ~14ft3 net.
Fi recommends 100in2 for both but that seems low to me. WinISD and speakerboxlite are giving me completely different port velocity numbers so that isn't helping. My gut says two 8" aeroports would be good.
I have not personally had great luck with multiple round ports vs single ports but I've seen others do well with them. I would also be looking for a lot more port area especially if you plan to throw some power at this.
Planning on clamping 3k. I'd go for a single 12" but I can't source one afaik.
It sounds like you need about 200 sq. inches. Maybe they meant 100 sq. inches each and not total?
38013
7.1 sq. inches per cube seems awfully small. I would guess 170 sq. Inches at a minimum.
That makes sense to me, especially when looking at WinISD. But also people run a single 8" port on (2) 12s all the time and and I imagine one of these 18s is somewhat comparable to (2) 12s. Also aeroports can be a bit undersized, maybe 100in2 of aero would perform like 150in2 slot? I'm totally lost on this one lol. I am very interested what your box builder friend says.
Did you tell Fi how big your box is? A 2 - 12's box equals around a 1 - 15 box to me. A 2 - 15's box is pretty close to a single 18, give or take and obviously sub dependent. One 12" aeroport might work (113 sq. inches).
I would if I could get one for a reasonable price. Sonotube seems like the only option but I don't want to add a flare.
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
822
what ^ said. amp gain setting info, test tones are at the very bottom...
339
Factory. 2021 Chevy Silverado custom trailboss
494
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Jonnyswboy
Jonnyswboy
Jonnyswboy
    May 8, 2024
    May 8, 2024
