Kicker 10cvr122
Ironhead79
Ohio
Looking for a decent monoblock amplifier to push 2 kicker 10cvr122 subs @ 2 ohm
I was actually looking at this one, just wasn't sure if it's too much RMS @ 2. Still green with electronics, lol.
It will be just fine. Head room is always good. Amp will run cooler and without struggling to serve the demand. Get your Big3 done, a good Couple AGM batts, and you should be just fine with the supply for the demand
It should have a built in fan also to help keep cool as well..
Mine has one, as well as my 1ohm version
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=22
Be sure to wire those subs properly to a final 2 ohm load and not @ 1/2 ohm/0.50
There already wired for 2ohm, wouldn't know how to wire them any lower and don't they can be. Thx for your help it's much appreciated. There currently on a Hi-fonics 1500 2ch, which I'm starting to have some issues with but it's had a good 7yr life.
434
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
929
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
Ironhead79
Ironhead79
Ohio
