Bobbytwonames 5,000+ posts
Trigger Man!
Moving along. I mounted the Soundstream and fed it some power, ground and remote signals. Mounted all 3 Knukonceptz power distribution blocks, one of which is used for grounds and is using solid buss bars instead of mini anl fuses. The large block is fused via 2 -100a mini anl fuses (200a) and the small block is fused as well but with an 80a (Soundstream) and a 150a (Rockford Fosgate Prime). Under the hood is a 300a circuit breaker. Cables are a mess but there is no noise. I am just waiting for my speaker wire from sky high then I will run those and the RCA's. Should be loud and clear. Then I get the Wavecor speakers, then we are probably going 3-way up front.
Is that a brace or a center divider in that port?
