WHAT AMP DO I NEED.
It says 200w rms (pair) so 100w rms per side. A 250 - 300 watt rms stereo (2 channel) amp would do just fine. 125w X 2 - 150w X 2. Don't buy a Boss amplifier. It matters if you are using the vehicles factory radio or an aftermarket one (A radio you buy yourself).
Alright thanks. Since they're 4ohm components. Does the amp need to be 4ohm? Could you recommend me a good amp.
Doesn't need to be but for simplicity, match the ohms to the speakers and the power to the speakers. Pioneer, Rockford Fosgate Prime series and Punch series, Kenwood.... If you are shopping, post what you find. We will let you know if the brand name is ok.
I found this one but it a monoblock. Could I use a mono block or does it have to be a 2 channel.
https://www.skaraudio.com/products/...hu6oP7-YT5-4IZHxdcG8TEj_7HV52T2caAlpjEALw_wcB
And I was looking at a Rockford 300 watt 2 channel. But it's just way to big. I something that will fit under my seat.
You don't want to use a mono - 1 channel amp for your components. You would have to use two of them. It needs to be a minimum 2 channel amp to be a stereo signal. I use a soundstream rubicon nano 4 channel amp and it rocks, it's very small and only cost like $150. It's 135w x 4
See, small. This is the marine version.
I found this one. Says it puts out 115W X 2channel on a 4 ohm setup. What do you think.
https://www.amazon.com/dp/B00CYSVI3E/?tag=caraudiocom-20
Ashton T
Ashton T
Bastrop Tx
ThxOne
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
