SPL Trunk 'Wall' Build Log
1 Ohm or 0.5 Ohm
  • 1.0 Ohm
  • 0.5 Ohm
Results are only viewable after voting.
The box will be built into the trunk and the trunk should be entirely sealed off from the cabin. If anything behind the seats is rattling that would be a failure to implement this design correctly.
Considering how much power and the cost of this build, the extra deadener would be justified purely as peace of mind to me (It's 0.8% of the total cost so I don't really care). I suspect the vibration can travel through the other surfaces in the car and end up vibrating in the trunk slightly. More deadener isn't going to hurt as far as I'm concerned.
If your trunk winds up rattling you should be looking at how well you sealed it off from the cabin. You absolutely should NOT be getting trunk rattling if you have sealed it off thoroughly.
When you wall off a vehicle, does making the cabin smaller raise or lower your vehicles resonant frequency?
Higher. You can usually guess where your best peak will be by measuring the cabin corner to opposite corner then dividing by the speed of sound and dividing that by 2 to find the half wave length.
That's not true. You're trying to be correct where it doesn't realistically matter, and you're not correct.
I've seen 2 american bass HD 12's flex the grill of a car and that's not even connected to the interior. Deadener stops rattling by lowering Fs of the metal by adding mass, adding mass to make the panel require more energy to move the same distance, therefore reducing flex from pressure.
Every single piece of metal on this car will vibrate with those subs LOL, probably everything with a 50 foot radius of this car is going to vibrate, if it's all correct.
Whether or not the box directly pressurizes the trunk is irrelevant, there will still be pressure differentials around the trunk panels, if not on the inside, then on the outside. Have you NOT EVER heard bass outside of car? That's why you'd deaden metal like he did, even if it's sealed off. It's still going to vibrate like crazy. Bass is still going to flex the trunk....there's bass on the outside of the car too lol. People driving next to him in traffic should probably deaden their cars too.
So you're saying OP should probably preemptively deaden his grille?
I'm not having any of those issues with either of the wall builds in my yard, we needed just a little on the rear deck of the Civic (which we should have just gutted in the first place) but suit yourself. Obviously it can't hurt but I would apply only as needed after everything else is together.
Don't play, you know what I'm saying. Clearly I'm saying bass touches everything within a certain radius of the car; deadening the trunk still keeps it from making noise.
Fuckbthem yinglong. If you want lto lishen holds better above 15 and has a tad better discharge. They have much more powerful cells I'd use than yinglong
This was the idea floating in my head but I couldn't put it into words this well. Thanks.
In 5s or 6s? 5s nominal is 12.5v which is a bit low. 6s is 15v which is too high for my PCM and amp as I would need to charge at 16v. 13.8v of the Yinlong is perfect. Also I would need 5 banks in order to match the 80AH of the Yinlong and I have a space constraint.
Arrived damaged, going to have to send it back and get a replacement. :(
30531
These subs aren't playing around. Since Sundown won't post T/S, I guess I can inform everyone that the RE of the D2 is 4.0. And they are confirmed rated for 3k.
30605
Jonnyswboy
CarAudio.com Exclusive
Jonnyswboy
Kickstand
