G6 GT Transplant/New Build
ThxOne
Premium Member
The Boss
I got my other G6 today. Not what the owner stated it was. He said 4 door 4 cylinder base model. What it is in actuality is a 3.5L V6 GT... just like my old one except two more doors. It has 102,000 less miles on it. Still has black leather interior and the factory Monsoon stereo which means direct swap over of my Kenwood head unit.This build is going to start out slowly.
So the OEM head unit is shot and only produces almost inaudible sound at max volume. This will motivate me to transplant as much as I can from the old build as quickly as I can. The only part that blows is it's another factory Monsoon system so I have to run my own speaker wires again.... maybe. Depends on where I mount the mids and highs amp.
I got the wipers swapped over as well as the headlight housings with LED headlights. The black housings with clear lens's looks good on the black 4 door. The new car had a minor coolant leak from a cracked and now replaced T fitting so as far as running it is perfect.
Don't hijack his build log thread bro. He already yelled at me for it. Just a heads up.
Listen, just because you can't read and you are then ask to not hijack a thread doesn't then mean you need to get your pink panties in a bunch and start being a smart ass. I didn't yell at you, you over sensitive ass clown. I used a period, not an exclamation point. Knock it off!
Not mad at all. I was just letting LSGUY to not do what I did. I rarely wear underwear, and, when I do it's usually something very unusual. You seem a little triggered.
718
892
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
775
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
839
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
ThxOne
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
