pls help me understand how to install lc7i
sounds_explicit
not sure on where or what wire to tap into to get signal. dont know what channels to use. trying to get a idea before i spend $ on this. clueless on these things. but im sure with a detailed explanation i can install it.. the video on youtube are plain dull and lacking anything necessary to help me understand what wires from where and use what channel..
im keeping stock radio. adding rockford 600.4 and wolfram 5k
how would you normally install a lc7i?
do the full range speakers go to the main
and the hi speaker lvl inputs go to channel 2?
then just jump the lc7i depending on what you need.?
so if i were to add 4 channel and a bass amp
do i take front doors speakers run pos neg from each front door back to the main and run rear doors pos neg back to channel 2?
then jump it inside to produce 2 channels and a sub channel?
other thing im missing is remote wire.. do i need to run a wire to the lc7i to the remote in? or is that not necessary and will i be able to supply a remote wire from that unit to 2 amps?
There is a guy on DIYMA or used to be that makes a harness for the GM stuff for adding in that sort of stuff so it works properly without too much hassle, ICR his name though. Might want to ask on there.
Use the lci for the 4ch then the Rockford pass-thru outputs to connect your wolfram.
I would call Kenwood Tech support. Im sure they will try to help you
Two ways to go about it. First, the easy way- Next, the budget but more involved way- On the second one, you buy the harness to install an...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
267
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
269
sounds_explicit
sounds_explicit
cleveland ohio
marc2112
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
