Help me please!!!!
TDIMN13
Hello, I have a 2013 VW Jetta with the fender audio from the factory. The car still has the factory head unit. The car already has amp wiring in the trunk. I hooked up the amp (power, ground rca) and the subs are not working. I also see two wires from the factory sub hanging down which appear to have an adaptor off the factory wires to sub in trunk. Any suggestions or help will be greatly appreciated.
Here are some pictures of what’s going on
I don't know anything about that Head unit. How is the amp is getting its signal from the HU. Are the RCAs from the AMP plugged into an LOC? If your amp is powered on and your not getting sound then I would look at the signal from HU. If that checks out then I would say check your amp for output with a multimeter.
Set the gain about half on your amp that would be a good starting point
So I pulled the head unit out and there is a LOC already connected. Everything is correct and getting power. I guess the next step is to check the output on the amp.
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
954
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
TDIMN13
TDIMN13
Minnesota
TDIMN13
    May 16, 2024
    May 16, 2024
