jeeper2269
When I did my last build, I ran separate wires from the battery to each amp inside the cab. My question is, do I need to do this again with these two amps?
amp 1 = teramps 3000.1 (0 gauge)
amp 2 = us acoustics Barbara Ann (4 gauge)
I am wondering if I can get away with running a single 0 gauge wire from the battery to a power block/fuse splitter, onto the cab and under the passenger seat. This will be where I mount the Teramps (due to size) and run 0 gauge the short distance to it, then run 4 gauge back to the rear cargo area for the Barbara Ann.
or..... do I still need to run two separate wires from the battery to each amp?
thank you
thank you
