What AWG is needed for @400amp?
diehappy
So, I had an audio shop setup my system. I paid them to do it and figured they would run what was needed.
I have a Audio Control 6x1200 and a Taramp Smart 3k. The alternator is CES 370amp.
They ran 1/0 CCA with a 300amp fuse.
I know or feel this isn't good enough. I bought a Limitless Cyber 6k to put in the vehicle. I will bypass the stock battery and run off the limitless. I was wondering what I should replace the wire with and fuse. I will probably run the wire into truck/limitless. Then take off that to the amps. I was also thinking of leaving the 1/0 in place and connecting that to the stock battery from the limitless but removing the negative from the stock battery and leaving that in place for backup. Thanks guys.
diehappy
diehappy
Daytona Beach, FL
Buck
