just grabbed Orion Xtreme 800 - thoughts
I've haven't been on here in two months. It won't take you long to figure out that IDGAF what you or anyone one else thinks. I post what I want when I want.
tracked it earlier,
itll be here tomorrow
I have the HCCA275g4 and XTR375.2. They are very good amps with great fidelity. The 275g4 uses 6 30 amp fuses and is a total beast. Had it powering 2 12" RF t0 and it was bliss. I crossed it over 100hz and it blended great with the front stage. Seemed as if I had subs in my doors.
Now, the 375.2 was sonically pleasing, but it seemed to lack power. It is rated for 93.75w rms @4ohms per channel, but it seemed more like 30. It was using a shared signal so that was not the issue. Ended up removing them because the 275g4 burned out. I had it connected with solid wire from the distribution block (for tidy looks), which ended up pulling on the plugs and just barely touching. Box mounting was a bad idea.
Only down side of the amps I would say is size. I am currently using more class d amps which are tiny in comparison. But other than that, nothing. You will enjoy it.
still have the blown 275?
I actually got this amp in a trade. It too was burned out with a shoddy repair attempt. Guy put fets, diodes, & resistors that had no business being there. It is a two channel, so side 1 & 2 are mirror images. After months of downloading gut pics we were able to verify which components were correct and resurrected it. I acquired the side screws at Lowes. I also made the legs out of 3/16" aluminum angle gapped from the side panels by 1/4" ferrules. Does not look as good as in my mind's eye, but side panels are no longer being scratched.
does anyone know where we can get 4ga power/ground adapter for the orions that will fit therse older amps?
this 800 i just got has 8ga adapter on it - who runs a system with 800w with 8ga wire... wth
mhyde71
PG FanBoy
mhyde71
Brattleboro, VT
