Redoing my wiring
cbuts
Hey im going to be redoing my wiring and doing 2 runs 1/0 to back amp rack distribution block and aldo putting in h/0 alt.
Two batteries under hood.
Can I run EVERYTHING off the second battery? Both 1/0 runs, all my alt and extra grounds ?
Or is it better to split it up?
Thanks
It does not matter just as long as the other battery is in circuit. I would run a ground and power(obviously) connecting the batteries.
Thank you, yes ofcourse I'm going to run power and ground from each, plus a ground from each to the frame..
Just wasn't sure if it was a better to run half to one battery and half to the other lol.
I'm just just run everything off my 2nd battery, big 3, extra grounds, and my 2 runs of 1/0 to back amp rack.
Thank you
Just curious, why 2 runs to the rear? I had thought 1 run of 1/0 ofc will handle up to 350amps? And for what it’s worth, my alternator is wired to my battery of course, but my run of 1/0 runs to the rear, right off the alternator. Connected to my lithium, then I have 2 runs from it to my md5000.1
cbuts
cbuts
canada,ont
JakeW
