Aero Port position help
Masted85
62
Alabama
23451
I’ve got a box I already had made for a different sub but it works with my new one. I don’t want to make another box so will this setup work? I’m just not sure of how the port will sit near the sub like drawn.
It'll work, but the port is too close to the driver. I've done something similar and it did work but it effectively made the volume around the port unused. It's hard to explain.
Wouldn't you be down to nearly 1 cube net after displacement of the port and driver?
You are correct. In an ideal situation, the port mouth is on the opposite end of the enclosure as the driver is. This allows a more even compression/decompression of the entire airspace within the enclosure. With the port very near the driver, it can create a tunneling effect of airflow and the perceived volume of the enclosure will go down.
And in an enclosure with multiple speakers utilizing the same airspace, ideally each driver will be equidistant from the mouth of the port. This is an error I see in homemade/custom enclosures here a lot. Not really related to this thread, but I felt this was worth adding to the above comment.
If you can fit the port sticking up, you could also do that and just have it flush with the top of the box and the whole port sticking out
23468
So like this? How far from the bottom of the box should it be? Where should the hole be positioned? How much of the port should I use?
6" port diameter I like to keep them 6" away from any walls. 4" port = 4" away, etc
I also like to keep the port end away from the sub magnet, whatever the sub diameter is sounds like a good minimum distance to me...
So either facing up or out the side would work? Also how long does the port need to be?
If I did as you said I would add the volume of the port to the volume of the box?
No. You would calculate the net volume of the box as the internal volume (remove the width of the walls from your measurements, and subtract around .2 cubes for the driver.
The volume with nothing subtracted is 2.188 FT^3. Sub is .11 ft^3, 2 braces I have are 0.0143 ft^3.
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
894
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
595
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
756
Masted85
Masted85
Alabama
shredder2
    Apr 27, 2024
    Apr 27, 2024
