Need Help on the full audio system
Reet
Hello all,
To start with, I have Pioneer stereo AVH-X4600BT
I am looking to install aftermarket speakers, subwoofer and amp for deep base.
I am going to buy
Rockford fosgate T 1692 Speakers 6x9: 4 speakers
Pioneer GM-D8604 class FD Amplifier
Rockford fosgate p2 enclosed subwoofer
Pioneer GM-DX971 class D Amplifier
Will this combination work fine?
Details are:
  • Nominal Impedance (Ohms)4-Ohm Speaker Type2-Way Coax Midrange
    Mounting Depth3.43" (87mm) Tweeter Mounting Depth
    Frequency Response (Hz)50Hz - 22kHz
    Power Handling (RMS)100 Watts RMS 200 Watts Max
    Sensitivity (dB @ 1W/1M)90dB
Pioneer GM-D8604 class FD Amplifier:
  • 4-channel car amplifier
  • 100 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
  • 125 watts RMS x 4 at 1 ohm
  • 300 watts RMS x 2 bridged at 4 ohms (250 watts RMS x 2 bridged at 2 ohms)
  • CEA-2006 compliant
  • full-range Class D amp technology
  • variable high- and low-pass filters (40-500 Hz, 12 dB per octave)
  • preamp inputs and outputs
  • speaker-level inputs via supplied RCA-type adapters
  • fuse rating: 30A x 2
  • 4-gauge power and ground leads recommended
  • Nominal Impedance: Dual 2-Ohm
    Power Handling (Watts RMS): 400Watts RMS, 800Watts Max
    SPL (dB @ 1w/1m): 86
    Fs (Hz): 26
    Xmax (mm): 13.3
    Le (mH): 3.7
    Speaker Connector: Dual 10 AWG compression
  • mono subwoofer amplifier
    • 500 watts RMS x 1 at 4 ohms (800 watts RMS x 1 at 2 ohms)
    • 1,200 watts RMS x 1 at 1 ohm
  • CTA-2006 compliant
  • Class D amp technology
  • frequency response: 10-240 Hz
  • variable low-pass filter (40-240 Hz, 12 dB per octave)
  • wired remote variable bass boost (0-18 dB at 50 Hz)
Please, help me out.
Thanks
Hey man! Welcome. Will it work “Fine”...yes. What’s your vehicle? the guys on here can likely
Make optimization suggestions if they better know your vehicle. That combined power If your proposed amps musically probably won’t stress your electrical too harshly but I would definitely compete a big 3 electrical upgrade.
-solid amp Selections, both Put out over their rated rms power.
-speaker selections are average to below average. What’s your vehicle? Any reason you haven’t considered components up front. Potentially skipping the rear aftermarket 6x9 coaxials in favor of a higher end Comp set in the front front may give you better soundstage and output. You could bridge your 8604 to the front and keep your stock Rear speakers on the pioneer hu.
- subs...meh...Dude at work had Two 12” p2’s, I was underwhelmed. Granted He had em in a Crappy prefab sealed. That said,if you’re looking for “deep“ bass You May want to target a 600-750watt rms sub and have a ported Enclosure built specific to that sub and your space availability. A
Sundown sa-12 d2 (A few bucks more) or even an e-12 d2 (same budget as the rockfords) would Be good options.
Thanks for your suggesion
Its jeep patriot 2007 top model
I am on the verge of modifying it to the extreme from the outside
I am looking for the deep bass at the inside
I am using the spare tire space for the sub and amp
(Spare tire will be installed on the tailgate)
Sundown: Sundown Audio SA Series Rev.3 12 inch Subwoofer D2 - 750-watt RMS
Is this sub you are talking about?
any suggestion on the amp to support it, I am following Bestbuy.ca for buying options.
Hello all,
I am going to buy
Details are:
    Fs (Hz): 26
    Xmax (mm): 13.3
    Le (mH): 3.7
Thanks
Might as well get the Pioneer GM-D9705 and save some room. It will be strong enough to run your whole setup.
Reet
Reet
Winnipeg, MB
Bobbytwonames
