Is the strut tower a good grounding point?
PR1M3R
I did my big 3 in 1\0 wire. I was at a local car audio place today and the guy said the strut mount would be a better place to ground than where I had it (bar across top of radiator).
Is the strut tower a really good place to ground?
Also, is the factory engine to chassis ground point on the engine usually the best place on the motor to run a ground from?
If the tower is a good place I will switch the battery and chassis ground to the tower.
Thanks guys.
Old thread, but hoping someone chimes in..are the strut tower bolts sufficient for ground or should I drill into the the tower to make my own ground? Don't want to do any unnecessary drilling.
Just thought I'd share..I'm so happy.:D Thanks again guys!
PR1M3R
PR1M3R
Yakima, Wa
imakul8
michigan born
    May 14, 2026
michigan born
    May 14, 2026
