Hi all
Im looking to have a headunit-less install. Need something that will pair to my phone via bluetooth for streaming
Would like something that will have a master volume control I can mount hidden in the dash and maybe some buttons for next and previous track selection. A mic for handsfree would be cool but not a necessity
Is there a device which will give me these options without having to run a headunit which can connect up to my 2 amps (one for comps and another for Sub)?
Been looking at multi channel amps which could run the comps and the sub from one amp but would need something to cater for the above functionality.
Also the smaller the scale factor the better as id like it all hidden as possible
Somethings ive considered are:
NVX XUBT3 - which has most of the Bluetooth functionality as I want but the volume control only adjusts the Bluetooth devices volume and not the amplifiers
Another option was an AudioControl 6XS with the ACR-1 volume control which the amps would connect to. Id still need a bluetooth module of some sort to solve the functionality requirements I want
Could also have a volume control mounted somewhere and then a separate bluetooth module with some basic control functions flushed into a standard dash rocker switch
Is there a reasonable/cheap priced DSP on the market which I can setup myself without any special equipment that will give me the option to connect a bluetooth module too? Do all DSP's have the option for a volume knob control?
Lots of options but if you have any better suggestions they would be appreciated
Thanks
Thanks
