Dual Kicker solo baric l7 15s 2k rms each
Down here in the Valle people love running L7s. I've heard a few that blur your vision when in the passenger seat(suv). I recall them all running Hifonics D class amps. Quite nice but too much for my taste.
dude they’re great! The l7 15s are so underrated and handle clean power so well,well over 1200 rms posted max rms rating
only thing is if you’re pushing them hard I’d only do 2-3 songs max On high amperage and then cool down, if ported you’ll smell when coils get warm, don’t say “they’re alright” no lol
You’re absolutely right sir it’s not that simple, have to add in box rise etc, and it’s strong strong electrical, but I also talked to company and they said at .5 expect to see anywhere from 3600 to 4K of useable amperage
Wattage. That would be on a resistive load not music. An L7 coil would never hold 2000 rms each anyways.
I’m sure you’re right as I have not been able to turn my amp even close to all the way up, but I know for a fact I’m pushing them way past it’s limits, synergy “says” my amp will make 4K on strong Electrical
L7 can do well in the right enclosure...
but 2k ea... I am doubtful.
One of my best friends ran two L7 15’s on a Crescendo 2k. That was pushing the limits of the L7s. They would go about 90 seconds at full tilt before they would start getting stinky.
If your pulling 4,000 amps I guarantee your way undersized on wire. I am going to say that you meant watts. I am a Master Electrician and the amount of wire to handle 4k amps would weigh as much as your car. The dyno test I have seen has that amp doing well over rated but clipping like a mother
Man y’all dumbaaaaa! Synergy efa 3k dyno 32? At 1 ohm I’m running .5 with box rise higher so! No as I said if you didn’t read subs are definitely far from seeing 2k each! But what they are seeing is a lot more than what they’re rated! And big 3 with 1/0 with a 1/0 ran to amp right after second battery/cap, a foot!-
I’m running my 2 l7 15s between 3700 to 4K rms each.
You can’t come on here and try to BS those who have been doing very loud builds for many years. 🤷‍♂️
Clamp actual output and you will see you are no where near that. I have 12k rms in amps and I see 6k actual power clamped.
Op...post up a pic of your clamped numbers like this...
21682
Then maybe you'll find some believers on here. This was clamped #'s with an AAK 4000.1 (dual power/ground) at a Usaci event last year. For daily use clamped #'s mean nothing Imo, with my Platinum 18 I'm probably getting considerably less Fyi.
No reason you can't get the sound you want with ported or passive radiator but if you have no ability to tune the mass of the passives you will...
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
808
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
813
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
921
Sc-slappa
Sc-slappa
Spartanburg
shredder2
    May 11, 2024
RedRyder18
    May 11, 2024
