Best amp for Sundown SA 10 d2?
I have a 2014 Cruze ltz and I’m currently running a sundown sa 10d2 (600 rms one) at 4 ohms on hifonics brx1100 in a custom ported box.. I’m looking to run the sub at 1 ohm but don’t wanna push too much power so I’m looking at some amps for it: Sundown sae600.1, Rockford prime r2750x1, or Rockford punch 500x1bd.. I’m looking for an efficient amp since I’m running on stock electrical and the brx1100 is power hungry (I’m using 4 gauge ofc nvx wire)
Wire it to 1 ohm. 1000 watts rms BEFORE box rise is fine with a stock electrical system. That amp fuse rating is only 60 amps.
It has 2 60 amp fuses, I just don’t want too much light dimming, right now everything is running fine.. I can always try it out and if it happens to be too much I can look elsewhere, I just wanted to be prepared lol thanks!
This is your amp correct? Shows a single 60 amp fuse and fuse rating of 60 amps. That's not much at all for a stock electrical system plus on music it will draw much less than 60 amps.
Weird. But you will never see a 120 amp draw on music. If you played a 40hz sine wave at 1 a ohm resistive load at 14.4 volts you might. But on music you never will.
Even if wiring to 1 ohm were to be too much power its as simple as turning the gain down.
So I wired it to one ohm and it has come to life now, and according to my car it never drops below 14.3 volts, I have the gain less than halfway and bass boost off and it sounds great
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
So I don't know what i'm doing but I really like the used H-KO but when i look at the specs it looks like it could overpower the sub if I'm...
19
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
979
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
869
Have an Xli 2500 as a sub amp in the music room, overkill for sure, never overheats, never skips a beat.
150
9K
ThinnestShark11
Porterville, CA
Slo_Ride
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
