Sfb 3000.1
The dyno video of the sfb says i would need a 270 amp alternator and one strong battery. It draws 260 on 1 ohm load. But it drew 350 on the 1.3ohm load. So maybe I just need to upgrade the alternator?
I don’t really want to mess with my warranty
Something cheap you can try in the meantime, if your phone has an aux port, is an aux 3.5mm to RCA cable. You can buy one on amazon or maybe at bestbuy for cheap and then play music or tones on your phone and see if it's louder. If it's not louder before it clips you're just not getting enough output out of the amp or it's not enough electrical.
I'd offer to scope your headunit and amp for you but I'm on the opposite side of the state by VT. If you want to make a trip out maybe but that's a long drive
Even a basic TL072 will do this function just fine. LoL. The joys of comparators!
34
5K
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
960
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
Neverenoughbass703
Neverenoughbass703
Woodbridge VA
Boomin_tahoe
    May 12, 2024
    May 11, 2024
