Will running 2 12s drain more power then 1?
  • 5
Retrofuture30
If i upgrade my single 12 to a dual 12 with the current amp im using for the single, will it drain more battery or drain the alternator?
I have a single 12 inch power acoustik goth powered on an power acoustik rzr1-2500d amp. Thinking about switching it out for 2 woofer enclosure and add a 2nd goth woofer.
Will this drain more power from car?
I used this kit
grounded it between a screw and metal door covering some electrical outlets in trunk. Same ground wire thickeness came in that kit
You'd have to get a dmm and a long piece of 12g wire about 25ft then you can test the ohm resistance to your ground point . Walmart has a pretty nice yellow colored multi meter for about $20 I use fluke meters for my testing it needs to be 1/2 ohm or less ideal is 0 ohms
That amp was tested at 2 ohms, not one
it’s a 600 watt amp at 2 ohms. Your dual 4 wires to a final 2 ohm load. So, no it would not be a good idea to split that amps power to two subs wired at 1 ohm. That would 200-300 watts going to each 1200w rms sub.Get a new amp
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
443
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
Retrofuture30
Retrofuture30
Louisiana
n2audio
    May 11, 2024
RedRyder18
    May 11, 2024
