New head unit not turning on
Russ130
I bought a pioneer avh-1300nex and install it to my 2010 Toyota Corolla. When I went to try it out it would not power on. I put the factory radio back in and still wouldn’t turn on. The factory radio was working perfectly fine before in the install. I checked the fuses and wiring and everything looks good. I tested the power and ground with a dmm and it testing at 12.6 V. Everything else in the car works but the radio any idea why ?
Got to be a relay switch or is there a fuse on the back of the head unit?
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
441
592
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
841
Russ130
Russ130
California
Russ130
    Apr 26, 2024
    Apr 26, 2024
