2 ohm 4000 watts rms needed.
XKawN916
Was hoping to get the taramps 5000 watt amp, but it's only 1 ohm. I got a good deal on a pair of 12 inch U series sundown audio woofers but they were dvc 2ohm woofers. 1500 watts rms each. Need a 2 ohm amp (am I right?) To run these. Would like something well over the 3000 watts rms they are rated for. Don't mind spending some monies, but I'd also like the best bang for my buck. Thank you guys in advance.
8k dont set to clipping, just set gains via heat levels and voltage drop.
MD5000.1 2 ohm version.
since you'll have box rise i'd recommend the 8k, its only 90 dollars more for 3000 more rated watts lol. Thats a pretty damn good ROI. when was the last time you can get 3000 extra watts for 90 bucks?
definitely gonna get the 8k. thank everyone for the help. i know i just hit send on the box rise question. had typed it and looked up box rise before i hit send. so, the 8k is my cure?
i would personally go with the skar audio RP-4500. 1D they also have a better version of this same amp for $900
It also lowers the amps efficiency and raises the current draw.
341
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
215
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
878
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
964
XKawN916
XKawN916
sacramento
marc2112
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
