I have a duel 12" Sub Box, what sub and amp combo should I get?
  • 5
What are the specs of the box? You really need a box to match the subwoofers you go with.
Really tough budget though. I would probably buy two Blaupunkt 12s and a Taramps MD1200 2 ohm.
What if I rather get one 12" sub that is better quality? I could sell the dual box. Would I see a big difference in sound between a 10" and a 12"?
Closest I could get. Save a little more and get the XO1244. Wire the 10's up one ohm.
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
489
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
344
Eldoggo
Eldoggo
Canada
Bobbytwonames
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
