Now I can't hear the vocals
  • 6
danielbea122
CarAudio.com Exclusive
360
42
Tampa
After adding all the bass my mids/highs are still just stock so figured I'd order the little taramps ts400x4 with some midrange and tweeters.
I have a kicker 2 chan LOC. Would I need another one to run a 4 chan amp?
If I'm correct I can order 4 8ohm speakers and wire to 2 ohms but I'm not sure. So what would be best to run with that amp?
You need a better LOC like an LC7i or even better a DSP or headunit. The TS 400x4 is a very small low power amp so don't expect alot out of it. 50 watts per channel at 4 ohms. Two mids and channels 1/2 and two tweeters on channels 3/4 would be your best bet.
Yeah just wanted a little power than stock to make it sound better in the car. plus I don't want to be pulling much out of my electrical.
Not changing the hu in this vehicle but if you think I need a better loc than that I'll do
So after some research I have decided to add some 6x9s bridged 200 Watts RMS x 2 @ 4 ohm. Easiest to install for me plus I have the amp already.
Any suggestions on what I should add that will sound decent with all the bass? 2way, 3way or coax?????
I almost feel over when I seen max power 2500 watts! 😂🤣😂🤣
Hey that fifth channel worked great for a single sa12 lol
Still not gonna throw it out even though it's bigger than 2 taramps 3ks lol
Was going to buy the little taramps 4 chan but I'mma give the one I have a shot
Taramps are designed to be small. Amps like Power Acoustik are designed to be big so that people think they put out decent power. Open it up and you'll see what I mean. You'll get more than rated power all day from the Taramps, you'll be lucky to get half of rated power from the P.A. If companies like P.A. didn't grossly overate their products then they'd be taken more seriously.
Amps like Power Aoustik are be signed to be big so that people think they put out any decent power. Open it up and you'll see what I mean.
I still watch this video for entertainment from time to time... lmao.
20" of heatsink with 6"-7" of board ... smh
That's ^^^ an extreme example I know, PA ought to at least have a full length board inside the sink... I hope
Yeah now I know it's crap now but when I bought it used from a pawn shop I didn't know the difference between 2ohm and 4ohm subs lol
Learned a lot from you guys about subs but the speakers seem even more confusing with all the brands/models etc
Anyways, anything has to be better than these sad excuse for 6x9s
LOL. Some of us have Issues that another can relate too. LOL 😂 😆
24
Get a Wrangler and get naked (you know…the Jeep, not you…none of us want to see that) and you’ll definitely be heard coming. 😉
Your amp may have failed. A competent shop should be able to diagnose the issue in under 5 minutes either way. You didn't necessarily do...
609c is very good for their price. I haven't used the Pioneer but I'd figure if they're comparable price they should perform similar.
danielbea122
danielbea122
Tampa
Timbo74
    May 8, 2024
DEW123
    May 7, 2024
